[quote=“kuraasu”]Hi Ahab,
[quote=“Ahab”]when i turned on the “heat printbed” it didn´t passed the 0.60Cº, far far away from the 50Cº…and then it slowed to 0.40/0,30º.
Then i checked the resistance of the connections between the board and the bed and all of them showed resistance values near zero, which is good, i think so. But measuring the resistence between both ends of the NTC it showed resistance near 800/900. I presumed the problem was in the NTC thermistor and i decided to resolder it. But unfortunately the problem presists…and the temperature never returned to heat up again and now the resistence in both parts of the thermistor is 1.
[/quote]
judging from your photo, I’m afraid you resoldered a bit too much. Like any SMD part, the thermistor needs only a small amount of solder underneath its pads to connect to the PCB. However, your error seems to be more in the opposite direction, i.e. it’s not short-circuited as one would suspect at first, but rather disconnected (I presume the multimeter did show “1” indicating overrange, and not “1.0 kΩ” or similar, right?).
If you have some equipment for desoldering, you can try to get the thermistor off the board in one piece. When using a solder sucker, make sure the thermistor doesn’t get lost in it, e.g. by holding it with tweezers when desoldering the second side. If successful, measure the disconnected thermistor to assess whether it’s ok or broken.
As for the board, you can test the heated bed input by switching the thermistor connectors. Both inputs have the same calibration, hence the indicated temperature on the input where the (working) extruder thermistor is connected should be the same, too.
Cheers,
kuraasu[/quote]
Hello Kuraasu!
Thanks for the help!
Yesterday i figured out a solution, but now i am facing another one, which i dont know if it has something to do with this latest problem:
I took off the thermistor, which was broken after the “desoldering” process, and put another one (not an smd, but the other resistance with 2 legs
), and then i measured the wires and they showed 6.6K (strange isnt it?) in the 200k mode in the multimeter, but the truth is that the program started to work and recognized the temperature (about 20º). Then i heated it up and it reached the 50º. Perfect!
Today i was finishing the calibration process and i was stuck in the bed flattening process…well, when i decided to move on to the printing experience the Bed temperature was on 250º! GRRRRR!!!..
Did i comitted some mistake while flattening the bed??
Now if i measure the wires from the thermistor to the therm 2 they all measure 0.00.
I have restarted the board, have resolder the thermistor again and the problem persists…250º in the bed!
Damn…what an headache this k8200…;(
Any solution??
Help would be much appreciated!
Thanks!
(BTW…Why did it work measuring 6.6k??? )
