I’m trying to discover what kits I should/could use to make a turn table (for photography). On the turn table I place an object ; The camera makes picture; the turn table turns; stops and the camera makes the next picture and so on.
The PC will be running Windows 7 x64. There is no parallel port available (I do have experience with the k8000 kit on a W98 system; I still own it, it is not used anymore).
I would love to use a K8005 (stepper motor card) but it says; Easy to connect to the K8000. Only the remark on a post of nov 9, 2010 VEL417 says “Sorry, due to the age of the kit, the protocol is not available”.
What kind of kits can you advise if I want to
- Control a stepper motor with presumably a strong motor (to turn a mass from eq 10-25 kg)
I expect to use a reduction to increase the power - Reading some switches (eq start / stop)
- Fire the camera (eq relay output)
- An “easy programming language” like Visual Basic.
- I needs to have good example source code.
The reason to use a PC and not a PLC or something else is convenience; programming the PC is hopefully a lot easier than a PLC.
I was thinking to use K8005 and perhaps the PCUSB13 (a USB to parall) and the K8000. But the remark of VEL417; makes me wonder. What can you advise?
Thanks for reading; hope you can find an answer
– Jeroen / The Netherlands
