I was having problems with when my X and Z Axis when first trying out my printer (solved), so I decided to try out all the Electronics.
When I use the move axis command 0.1 mm on the extruder motor, it doesn’t move.
The motor, cable and driver board are all perfect.
The only thing I can think of that could be broken is the Motherboard itself, but before I return it, I would be glad if you could share some ideas/advice.
