I have Some trouble to adjust the offset.
When i connect The red wire on THE test pin The lowest value is 1 volt and not 0.00
When I measure R1 and R2 both are 10ohm and not 2,2
What is the value displayed on the screen after this procedure:
After this procedure is the value on the test pin:
1.44v, not contious (between 1,38v and 2.13v)
Very strange result.
What value is displayed in the last step of this procedure:
Can you adjust the offset trimmer until the value displayed is 0.00V ?
Is the trace stable and in the middle of the screen?
[quote]When I measure R1 and R2 both are 10ohm and not 2,2[/quote]What is the color code on these resistors?
The resistors color red red gold Braun white
First thing straight:
Are there more ways to calibrate?
[quote]- test leads together 0v
It seems that your EDU08 is properly calibrated.
[quote=“VEL255”][quote]- test leads together 0v
It seems that your EDU08 is properly calibrated.[/quote]
Thats means the manual is wrong?
The test pin Will be 0v
[quote]Thats means the manual is wrong?[/quote]Can you please elaborate on the issue.
This is what you should see on the screen when the red lead is connected to the test pin:
My excuses I got it wrong.
I have mix 2 things.
Thanks for our time
This case can be closed.
OK - No problem.
Enjoy your EDU08
