It takes a long time to heat up the bed to 60°, and 120° for ABS will be much longer later.
I have a 12 V, 12.5 A power supply here, is it possible to heat the bed with this power supply but still control the temperature with the original board and the repetier software?
At the moment i have 24v on my bed, switched with a 12v relais, connected on the original board. Reach 100 degrees now. Forget 12v, not enough, velleman ps is already 15v.
The bed has a resistance ® about 6 Ohm.
The power supply has a output-voltage (U) of 14.7 V
Following Ohm’s law (U = R x I --> I = U / R) there is a current (I) of 2.4A
So with 24V you have to expect 4A
No idea if the pcb-tracks are designed for this current …
At the moment, i just use the output of the board to drive the relais. (Only for the bed!) so i can regulate the temperature like before.
And the 24v is connected through the relais to the bed. Works fine with a glass plate and kapton tape.
If i kill the bed die to overheat, i already have a mk2a 12v 1.5ohms ready.
It is not clear for me how to connect the heatbed (maybe mk2 or something like that). I think a normal relais is not the best solution. Its better to use a mosfet.
But I don’t have any experience with mosfets.
I would also like to have bit more reserves, in particular when needed cooling with the fan. Connection with a MOSFET could be done as follow. I dont know if the IRFP460 is appropriate, since it has a resistance of 0.29Ohm, so at 5A current it has to handle 7.25W. I would prefer the IRLR8743PbF with 3.1mOhm.
But before I apply more power I would like to know from Velleman if the PCB heat bed can handle 24V.
Based on the original head bed (assuming 15V/2.4A, did not measure) has 36W, with 12V 1Ohm 12A you would have 144W (!). The IRLR8743 with 3.1mOhm would handle 12A12A3.1mOhm = ~0.5W sould not be a problem. I would
though use heatsink.
The bed is a resistor, designed to produce heat. If driven with a larger voltage, it gets hotter.
Given 15V/2.4A it has a resistance of 6.25 Ω.
When 24V are applied, the resistance results in a current of 3.84A, which in turn results in roughly 92W, about 150% more than the original design.
Since there’s a PTC sitting right in the middle of the business, any damage to the hotbed could only happen if the power input to the hotbet would heat it so fast that the controller would be unabled to turn off the power fast enough to prevent overheating.
I severely doubt that. To overheat an area of 400 cm² within a few seconds, you’d need much more power.
It might be advisable to replace the heatbed wiring from four parallel ribbon cable conductors to something more substantial, but otherwise only the ribbon cable would get warm.
[quote]Well: What could happen?
[/quote]
Acually your are right. So I build a prototype of a 24V MOSFET controller, but to completely decouple the extra voltage from the controller board, I changed the electronic design and use now a optocoupler. Now I can keep the bed at 60° even with 2 fans at 100% speed ;-). 3.9A@24V=94W
(With 12V input will you have to change R2 and R3 to 1.2k !)
Edit: The MOS-FET can also be the IRLU8743PbF (I-Pak version).
Edit2: Note that schematic signs and hardware pinouts generally do not correspond! This may be a trap for less experienced users. If you have built this circuit and you get a “alway on” output, check wiring and pin numbering of the optocoupler.
The linear voltage regulator (7805), responsible for generating the 5V needed by the AVR microcontroller would get slightly warmer, but still is within specs.
The stepper drivers can handle voltages up to 35V, so they should be within specs.
What remains are the power mosfets for both heaters and the fan – which by the way already is outside specs by the original design, supplying it with 15V instead of rated 12V.
Edirol, according to your first schematic: Is R1 = 18k and R2 = 10k suitable for 12V input? Or do I need to change one of them?
Or is your second schematic with the optocouper so much better and I should change completely to this way?
Yes you did. The extra power comes from a additional power supply.[/quote]
Thanks for both of your replies, but I’m afraid that you’ve missed the point.
Of course I understand edirol’s idea to use a secondary supply, and his way of adapting it to the controller’s circuitry.
But that wasn’t the point.
I’m trying to think a little bit farther. Why use two power supplies if one would suffice? Why the hassle with (manually?) turning on two power supplies? Why the hassle with the wiring, needing two wall outlets?
To implement edirol’s changes, a new power supply is necessary. But if a new power supply gets bought, why not one (powerful enough) to run the whole thing?
A 24V/10A supply cost less than 60 EUR (in Germany at least: reichelt.de/ARTICLE=57491) and would be sufficient for a 100W heated bed, the stepper drivers and the extruder.
A problem might arise from powering the extruder’s heater with 24V, a 150% increase could make it too fast. And the PWM-driven 12V fan might be less than happy when being supplied with 24V instead of 15V (which is already outside it’s specs).
[quote=“flo_s”]
Thanks![/quote]
Pls take the second one
Yes, but then you would have lower power at all.
Ok, now I understand. Of course you can make this consideration. But then you have to recalculate the curcuit., the on board components will get hot for sure and driven at its limits. With the external power supply the board is completely isolated and doesnt touch any other components (voltage regulators, transistors, extruder, motor driver ect) except the heat bed.
