Question for those of you that have added a 24v supply, now that you can go much hotter on the heatbed, do you still print PLA on a 50 degree bed, or are there any benefits, like better adhesion, to going hotter? Or going hotter for the first layer?
Iāve always printed PLA at 60°C, lowering to 50°C after the print for easier removal.
So - yes. And keep it at 60°C throughout.
[quote=āProcessaurusā][quote=āErik Mā]You donāt need any additional components to run the hotbed on a higher voltage.
You do like this:
A - Connect minus of the second powersupply, PSU, to the minus of the board.
B - Connect one wire from the hotbed to plus on the 2nd PSU.
C - Find Heater2ās two +15V pins on the K8200 motherboard and clamp them out of the way.
D - Connect the other wire from the hotbed to Heater2ās two remaining [drain] pins.
E - [optional] Add a Heatsink to the Heater2 MOSFET.[/quote]
Thanks for the encouragement. Did a version of this today, using the onboard mosfet to switch the 24v to the heatbed. I did mine by using the PCB power barrel connector for the 15v supply, and the screw connector for the 24v supply. I cut a couple traces on the PCB to isolate the Heater 2 (heatbed) power input, to change it over to the 24v. I connected the barrel connector over to Heater 1 with a short piece of medium gauge wire. This way everything on the board is running on the 15v, except the heater 2 (+) connection is connected to the 24v supply. The 24v supply (-) is connected to ground, so when the mosfet turns on, the heatbed (-) is connected to ground, and the 24v runs through the heatbed, thru mosfet, to ground.
This way runs the LED for the heatbed off the 24v supply. I changed my LED resistor, R15, to 3K, but Iām not sure this is necessary, the original resistor is 1.8K, probably within safe limits for the LED current, as tiny as it is. I like the LED not being run off the 15v supply, because LEDās donāt like have voltage reverse biased, Iām not sure what the reverse breakdown voltage of our LED is. But, even if it died, there is the 1.8K resistor in series, so, even if it fails short, the +24v and +15v is only connected together with a 1.8k resistor, no safety issue for the rest of the electronics, just that LED.
[/quote]
Today i successfully updated my printer following your post.
Instead of a 24V PSU, i used a 22V one (i had it available). For the first tests, everything is working as expected.
The bed warm up to 55ĀŗC in about 3m30s. Outstandingā¦
Thanks for the sharing.
I know this is an old post, but when someone reads this and doesnāt want to mess with PCB please do check my solution at https://www.youtube.com/watch?v=kX8JLeA1VZQ
Iāve printed a mountable enclosure - itās all in the video⦠Hope it helps you.
