Add Profile for HIP
I have recently finished building my dual-nozzle K8400 and as well as PLA filament, I also have some HIP filament for soluble supports. There is no profile for HIP on the repetier host or the printer itself, so how can I set one up?
As well as this, how would I set up a profile for loading HIP and preheating?
Thanks,
Daniel
HIPS uses the same profile as ABS.
Thank you for this information. If I did wish to use a different material, what could I do to make new material profiles?
You need to load the abs profile and then use the ‘save as’ button and save the profile under a different name. But be careful, for whatever bad UI reasons, repetier host does not do ‘the right thing’ - you can’t save specific print speeds & extrusion settings with filaments, just flow rates and temperatures. The others get saved as head configurations. Makes life tiresome for those of us who print with flexible filaments occasionally… :frowning:
Ah I see, thanks for the info.
The Repetier software is a little temperamental at times, and the default values appear to be far from optimal in some cases. Speaking of which, is there anywhere I can find optimal settings for each filament?
[quote=“SlowFoot”]
No, you have to test out very filament yourself. Specially as the Vertex is “a bit” unreliable in the default settings and temperature readings.[/quote]
I see. I would have thought there would be a thread on this sort of thing but I guess not. Not to worry, I’m sure I’ll get it right in the end!
