Does anyone know if it is possible to use Access k8055/K8061.dll from a webpage using createobject, and if so how to refer to it, that is what to put instead of “???” Server.CreateObject("???"); and how to and where to install the k8055/K8061.dll on the IIS-webserver?
If I’m not mistaken, CreateObject is used with COM objects. The K8055 or K8061 DLL does not contain a COM interface, so this will not work. There may be other ways to do what you want to, without CreateObject, try searching the forum.
