ABS won't stick, need to increase hotbed voltage
Hey, when I’m printing with ABS after a few layers the model gets loose. I know this has to do with the hotbed not being hot enough, how do I increase the voltage of the hotbed? Is there a more easy way, or do I have to for example build this circuit and buy that external power supply?
k8200.jimdo.com/app/download/866 … 1384195223
Any idea?
Bindle
All is explained here
viewtopic.php?f=53&t=9598&hilit=24V
No need to power up your hotbed.
It works for me fine to use white painters tape, hotbed on 55 C, hotend on 240 C, no use of cooling fan.
Awesome, can try.
Bindle
Il faudrait vérifier que la thermistance du nez n’est pas cassée ou en cours circuit.
Surtout, ne pas essayer de dévisser l’extrémité de l’extrudeur à froid au risque de tout casser.
Il faut démonter le nez à et enlever le plastique coincé avec un nez chauffé (180 par exemple), mais avant il faudra résoudre le problème de la thermistance.
Bon courage
Download high quality 640-878 latest exam dumps dumps to prepare and pass RIVERBED with oracle certification.
