Yeah, same with the original Vertex it does not have a heated bed. so you need to mod it.
I don’t own a delta. But I have the k8400, that I have installed a heated bed on.
Its not too hard. But if the board is similar to the k8400 you need an additional PSU and a solid state relay to connect a between the PSU, bed and board.
After taking a look at the schematics, it looks like you’d need to to some modification to the board and firmware to make it work since I cant find any free outputs for a heated bed.
You would probably need to assign some other unused pins on the board for that.
This is maybe a stupid question, but does the bed actually have to be controlled by the main board, or does it just have to be on while the machine is printing?
Is the board more limited than on the 8400? I was hoping to also rig this thing up to octopi, but that might also be an issue?
(sorry for the probably very basic questions, it’s hard to grasp all these nuances for a newbie).
