IK HEB RECENT EEN VERTEX K8400 AANGEKOCHT
MAAR ALS IK PRINT MET ABS BLIJF DE PRINT NIET OP HET BED PLAKKEN HEB AL VERSCHILLENDE DINGEN GEPROBEERD MET TAPE MAAR DEZE KOMT ALTIJD LOS IN SLICER MET BRIM OF MET RAFT NIETS HELPT KAN MIJ HIER IEMAND MET HELPEN
Please post in English or French on the forum and do not use all caps.
Can you specify the height of the nozzle to the buildtak on the first layer?
nozel hight is 0.15 from the bed
[quote=“KURT”]nozel hight is 0.15 from the bed[/quote]That should do it. Make sure your Buildtak is perfectly clean (oil can drip from the rods above). Use (isopropyl) alcohol to clean it.
