As an organizer of a game are I for quite some time in search of chrono which can be served by means of an external start and stopper. At Gotron in Aalst (Belgium) have this way actual what I zocht. The product which they presented me measure the time is: SOPHISTICATED UP/DOWN IMPULSTELLER K8035 Toch there is a problem as a result of which I cannot use it. The problem is that this toestel counts only the seconden. There is the possibility a small of doing adaptation to this toestel as a result of which up to on a tenth of a seconde the time can be measured? Gotron me after the recommendation are able further help.
Hoping on positive recommendation, I you greet pleasantly
Software modifications, even very small ones, require a lot a work, both for developing and testing. Unfortunately, our engineers do not work for free, so we cannot supply modifications on demand. Furthermore, our organisation is not geared towards custom design, so even if you would be willing to pay for it, we would have to decline your request.
I think you can always use it in counter mode. Connect an oscillator with a maximum output tension of 5 Volts and a frequency of 10 Hz to point “SW1”. As long as this signal is available the counter will count in tenths of seconds and seconds (I mean modulo 60 is not working correct here; if you measure let’s say 2 minutes the display will read 1200 = 120 seconds = 2 minutes)
