I have 8055.I am Beginer in this filed.I want to display the data of various sensors.Details of the sensors are as follows:
1.Humidity Sensor
Vcc = 5v, Vout = 1.3358v to 3.6v at (0-100% RH) , Iout=4mA (5mA max.)
2.Rotational speed Sensor
Vcc = 12v (16v max.) , I out=7mA (Low),I=14mA(High), Freq.=25 KHZ
3.ThermoElectric Sensor
Temp. Measurement; No input current or voltage; Vout=(-3.553/41.269v) at -100/1000c
In case i use two of these sensors at the same time then
A) Can you please guide me that what cahnges in the circuit of 8055 be done in case of each sensor.Do i have to amplify the signal by putting R8 or R9 or it is not required keeping in view the sensor output signals(magnitude and polarity).
B) I am using vc++ for this puropse. do i have to write a code for this or the code in the demo version is sufficient.Can you please help me in providing the codes as well.
C) Lastly please tell me what is the purpose of clamp on the digital outpuut side and in which case it is used.
Thanks,[/code][/quote]
