8055 and thermometer or humidity sensor
I just bought the 8055 and have started writing programs for unix.
I would like to know how i connect a thermometer or a humidity sensor to it.
This is thee humidity sensor i have at home
elfa.se/pdf/73/730/07305675.pdf
And this is the thermometer
elfa.se/pdf/73/737/07377559.pdf
Can I use any of them?
If so how do I connect them?
If I cant use them can you recomend some circuits that i can use?
Thanks for any replies.
The humidity sensor fits very well to the K8055’s analog input .
Just connect its output to the analog input A1 or A2 and connect its minus lead to GND and plus lead to +5V of the card.
Remove the jumpers SK2 and SK3. You’ll find the +5V from the upper pin of SK2 and SK3 pin headers.
The thermometer DS18B20 is not possible to connect to the K80565 due to its digital communication speed requirements.
