8048 upgrade files?
I have the Vellerman 8048 programmer and wish to use more modern chips than which it was first designed for. The 16F88 is pin compatible to the 16F84 so is it possible to update the PICprog software to allow the use of this IC or am I limited to ICSP.
Also is ICSP standardised as regards pin out as I have seen different pin number versions around. What is the pin out for the 8048?
TIA
Pete Harding
