3d printer 8400 display not working
all plug connectionions are pluged correct (double checked) but the
display is not working.
do you have any indea ??
regardes Rolf
Make sure none of the reset buttons (the one you mounted and the one on the LCD) are not pressed.
Do not plug the cable in to the print head until you have this fixed.
Also check if the 2 parts of the display are correctly plugged in.
Thank You - Wrong Way - thank you - Raby -
Yes both parts of the display are correctly plugged in
Yes both reset buttons are not pressed, both reset buttons are functioning
Did you check the contrast of the LCD
thank you Vel337
yes I checked the contrast of the LCD.
Have you checked the output of the power supply?
Should be 15 volts DC.
If you are in the USA there is a switch in it that needs to be changed.
Thank You Wrong Way,
I checked the output of the power supply
it is 15.13 volts DC.
regardes Rolf
You may need to get Velleman to help you get a replacement.
thank you Wrong Way
yes I also think I net a replacment
Please visit support.velleman.eu for exchanging broken parts
best regards,
VEL337
