3 VM131 and only 1 push button ->?
I purchased 3 VM131 modules and I want to control them with only ONE push button.
As soon as I connect the second VM131 module, the system becomes out of order.
Do you have any solution ?
Merci,
Thierry
VM131 circuits cannot have a common. Three units must be totally separated. Use either a pushbutton with three seperate contact sets or use a relay.
I have an similar problem. I would like to pilot two dimmers from two push buttons. But I have only three wires to pass my push buttons. Can I use one wire as common ?
schema :
.-------------- PB entry on VM131-1
PB1
|-------------- PB entry on VM131-1 & PB entry on VM131-2
PB2
`-------------- PB entry on VM131-2
thanks
No, please check previous post: None of the two pushbutton terminals may be connected in parallel with a terminal from a second printer.
You will have to use relays.
