The VM 100 kit specifications are:
damping factor: >800
How is this possible because publication Elektor September 2007 mentiones that the “output resistance at 40Hz” (page 28) of this VM 100 module is 424 milli Ohm. When I do a calculation with a loudspeaker box of 4 Ohm then the damping factor is: 4/0.424=9.4 what is far away from the 800 which the specification of velleman tells us.
Please explain this.
The elektor is to see at:
radio-portal.ru/book/%C6%F3% … 0709Uk.pdf
Regards
John / Lake.
