Is it possible to mount two K4004b’s on to one K4006 in combination with 22518 transformator?
And if so do i have to place two extra caps on the K4006? (i do have two spares).
They will be processing the same signal
No, to avoid problems each unit requires K4006 and transformer.
Extra caps are not necessary.
Thank you for the reply. just one question, can i use the transformer 22518 for the both of them?
For best results, we recommend separate transformers.
