2. Fan
Hello
I am thinking about a Fan for the Board. 0.1A or 0.15A.
I use the standard 15V supply with the VM8202 Led ring a I will use the VM8201 controller (ordered).
Is it possible to connect the second fan on the same like the Led ring or the same as the first fan? Or is it better to use a 12V power supply additional?
I have read other threads about this, but i am not sure, i think 0.1A more is possible…
Regards Roger
You can connect it in parallel with the 15VDC power supply but use a small resistor to drop the voltage to 12VDC.
Fine. Many thanks for your replay.
