2-channel RF FERNBEDIENUNGSSET, VM purchased 130, and now I wanted to ask, (technical issue), and got the garage door with the engine, it is 2.30 cm tall, and rolls up and down, but I wanted to ask, what is the setting ON / OFF, there are 0.5 pulse, and then 5sec timer, and then 30sek.timer and so on until an hour … I just want to send only a remote, yes, boots garagento, and from, respectively, the second button on the remote, it shuts down , 1.frage, which means the on / off, 2.What would be the best setting, the garage door was 2.30 cm gross, please help me
Sorry, we have difficulties understanding your question.
Please post in english or french. Maybe someone can correctly translate your question?
I have a garage door with the engine,the door are 2.30 cm tall, and rolls up and down…
i have 2 channel rf fernbedienungsset for the door (to open and to shut down the door) with 0.5 pulse with a 5sec timer, and then 30sek. timer and so on until an hour for opet/shut the door…
On how much shoud I set the timer of this “mashine” for a 2,30 cm door?
My english is not so good, i hope u understand it… Thanx
I think I may understand.
Just to make sure are you asking how long the relay should be engaged to open your garage door?
If your doors are like the ones in the USA normally there is a button that you press for a very short time.
When the door gets to the open position it hits a switch and turns the motor off.
The same thing happends when the door is being closed.
If this is the case for your door I would think you would want the shortest time avaliable.
0.5
I hope I got it right and that this helps.
