0V line on EDU09 display
This might be a bit of a stupid question, however I’m not so familiar with oscilloscopes yet. I just want to check that the 0V-line on the y-axis of the EDU09 “display” is where the “1” is. From what I have googled, the number on the y-axis refers to the channel-number. Of course the EDU09 only has one channel, and hence “1” appears on the y-axis where 0V is. Is this correct?
Yes, this is correct, the “1” indicates the vertical position of 0 volts for channel 1.
Ok, thanks - just wanted to confirm.
