Have Pushed “Connect” Instructions tell me that I should see the Extruder and Bed temperature at about room temp but I see:
Have: “Connected Extruder: 0.00°C/Off Bed:22.50°C/Off Idle”
I assume this means there is an issue with Extruder Thermister…? either wiring or no resistance?
Does this issue prevent testing of the Z-Axis under the next step as I get the following:
“Printer stopped due to errors. Fix the error and use M999 to restart! (Temperature is reset, set it before restarting)”
This is not a terribly helpful error statement.
Where do I start?
Todd
