So while printing at 0.05 / 0.025mm i get some weird layer wobble, any idea of what’s causing this? (0.1mm and above is perfect)
Cmon… no suggestions?
You can try change the layer height to 0.0525 for 0.05, 0105 for 0.1 and 0.2015 for 0.2
Those values are more accurate in respect of the z rod thread
Do you mean the ringing towards the corner?
These are caused by the speed of the print head. When it changes direction it can oscillate a bit. that is why you only see these artifacts near sharp corners.
The simple solution to this problem is to print a bit slower. The harder solution is to tweak the acceleration settings so the printer would decelerate more towards the end of a GCODE line and accelerate more in the beginning.
