I have a class and they soldered this kit together. And then some of them finished and they were not working. Which is normal, so I had them go through double check with a multimeter and so forth. Then I checked and everything seemed fine. And I was stumped. Then more weren’t working and none of them were working. I have one that I made several years ago that works. So I swapped the IC and then the student’s project worked. They all worked with the old IC.
I stuck the new IC into mine, and nothing. I went through and stuck all 14 ICs into my older dice and nothing.
It’s been 2 days and still haven’t heard back from customer service. And the kids would like an answer I don’t have.
I have seen your post in customer service and sended a reply.
We have checked the production. We have identified this problem. The PIC’s had a wrong ID number while programming, so these are not working. For which we apologize.
For others that experiencing the same problem, Open a new ticket on customer care, via this link: Customer Care Velleman. Add the invoice, photo of kit and PO number of kit.
