[quote=“0L1”]Could you please explain what PID-Settings are?
Where do you specify these settings?
What values do you recommend?[/quote]
It’s all explained here : http://reprap.org/wiki/PID_Tuning
[quote=“raby”]
It’s all explained here : http://reprap.org/wiki/PID_Tuning[/quote]
Thanks raby for the link.
I wonder how much sense this procedure makes if the measured temperature might not correspond to the real temperature at the noozle.
Do you expect the behavior to be compareable between all Vertex printers or is it something which differs fundamently between the different Vertex printers?
What is your standard temperature for printing PLA?
Best Regards
Oliver
i just checked my nozzle temperature, and it’s 32 degrees higher then the display value
i print PLA perfectly at 166, and the temperature probe shows nozzle temp at 198
