Hey there,
I did as you instructed, but the white screen still is all I keep seeing. I reconnected all cable pins did a firmware upgrade to version 4.0 with the help of this thread :
https://forumtest.whadda.com/t/vm211-i-cannot-upgrade-firmware-please-help/33039/16
I did that four times
The first 2 times I got a message the ino file wanted in the folder ‘EarthListener4v0_final’.
After clicking ok the folder was created and I pressed the upload button I got an ardafruit error message.
Then I created the folder ‘EarthListener4v0_final’ and the following error showed "A12 was not declared in this scope. I don’t have the VMA318 LED installed, so I figured this message was related to this. However the screen did not show any difference.
I copied the error message and placed it below :
Arduino:1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board:“Arduino Uno”
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino: In function ‘void controlLED(char)’:
EarthListener4v0_final:154:14: error: ‘A12’ was not declared in this scope
#define LEDg A12
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:162:24: note: in expansion of macro ‘LEDg’
digitalWrite(LEDg, LOW);
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:154:14: note: suggested alternative: ‘A2’
#define LEDg A12
EarthListener4v0_final:155:14: error: ‘A13’ was not declared in this scope
#define LEDr A13
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:163:24: note: in expansion of macro ‘LEDr’
digitalWrite(LEDr, HIGH);
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:155:14: note: suggested alternative: ‘A3’
#define LEDr A13
EarthListener4v0_final:156:14: error: ‘A14’ was not declared in this scope
#define LEDb A14
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:164:24: note: in expansion of macro ‘LEDb’
digitalWrite(LEDb, LOW);
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:156:14: note: suggested alternative: ‘A4’
#define LEDb A14
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino: In function ‘void lightningscreen()’:
EarthListener4v0_final:147:19: error: ‘A10’ was not declared in this scope
#define BuzzerPin A10
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:901:42: note: in expansion of macro ‘BuzzerPin’
if(BuzzerEnabled){digitalWrite(BuzzerPin, HIGH);}
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:147:19: note: suggested alternative: ‘A1’
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:905:42: note: in expansion of macro ‘BuzzerPin’
if(BuzzerEnabled){digitalWrite(BuzzerPin, LOW);}
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:909:42: note: in expansion of macro ‘BuzzerPin’
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\functions.ino:913:42: note: in expansion of macro ‘BuzzerPin’
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino: In function ‘void setup()’:
EarthListener4v0_final:153:16: error: ‘A11’ was not declared in this scope
#define LEDgnd A11
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:83:13: note: in expansion of macro ‘LEDgnd’
pinMode(LEDgnd, OUTPUT); digitalWrite(LEDgnd, LOW);
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:153:16: note: suggested alternative: ‘A1’
#define LEDgnd A11
#define LEDg A12
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:84:13: note: in expansion of macro ‘LEDg’
pinMode(LEDg, OUTPUT); digitalWrite(LEDg, LOW);
#define LEDg A12
#define LEDr A13
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:85:13: note: in expansion of macro ‘LEDr’
pinMode(LEDr, OUTPUT); digitalWrite(LEDr, LOW);
#define LEDr A13
#define LEDb A14
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:86:13: note: in expansion of macro ‘LEDb’
pinMode(LEDb, OUTPUT); digitalWrite(LEDb, LOW);
#define LEDb A14
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:250:11: note: in expansion of macro ‘BuzzerPin’
pinMode(BuzzerPin, OUTPUT);
C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\setup.ino:272:31: warning: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
if(SD.exists(logFileName))
In file included from C:\Users\Edward van Brummen\Desktop\VM211 Firlmwear\EarthListener4v0_final\EarthListener4v0_final.ino:21:0:
sketch\src\SDmega\SDmega.h:90:11: note: initializing argument 1 of ‘boolean SDClass::exists(char*)’
boolean exists(char *filepath);
exit status 1
Dit rapport zou meer informatie bevatten met
“Uitgebreide uitvoer weergeven tijden compilatie”
optie aan in Bestand → Voorkeuren.
As I am unfamiliar with the Arduino software I clicked upload a couple of times, a bar ran until it was full in the Arduino software, but nothing showed on the display of th VM211, it remained white.
Maybe this is better explained in my native language which is Dutch as shown in the error message at the bottom.
Thanks in advance,
E.A. van Brummen
