Hi to all.
I use 3 K8061 / VM140 cards for my Dominica. It works really suburb! I use to analog output for controlling my lightdimmers. 0-10V means 0-100% dimmed. So 10V is light off and 0V is light on.
Here is the problem:
Sometimes 5 times a day (or night) and sometimes ones a week an error exists.
All the analog outputs are set to 0V due to a failure at the TLC5628, IC7.
Let me explain what then happens:
All the AO’s are 0V this means that 8 lights are burning, but if I change one of these lights the other 7 are set to right value. I can now conclude that data is send again to IC7 and gets loaded again and the AO’s are set.
My problem is that this also happens at night and the bedrooms are lit at full strength…
I can simulate it by get the CPU above approx 85% load, so I think the is a problem with the driver from velleman: If the driver get not enough time to ‘do his thing’ the data does’t get loaded and all AO’s are zerro Volts until there is a change into one of the 8 AO’s and the data is send again.
Anyone has the same problem? or better a solution?
Alex
Belgium
