VM140 Error: 5
I found a problem when I call the DLL function Connected.
This is the secuence:
I Open correctly the card 0 wiht OpenDevice.
I disconnect the USB wire.
When I try to call any function after this, the DLL display “Error: 5”, why??
If I call the “Connected” function , the return value is 1 instead of 0, why?? (PowerGood fnction works properly)
If The USB is disconnect before call OpenDevice, the Connected function works properly.
My application is based on the C example but with a Connected and PowerGood functions call (why the example program not use the Connected function ?)
I’m using k8061_softwarepack_2011.zip package
can you help me, thanks.
I tested the same with the example of VC + + 2008 and works properly, the Connected function returns 0 when the USB is disconneted, but I need use mingw at windows SO (MinGW-gcc440_1.zip)
[code]#include
#include <windows.h>
#include
using namespace std;
typedef void(WINAPI *t_func0)();
typedef int(WINAPI *t_func5)();
typedef bool(WINAPI *t_func9)(int);
t_func5 OpenDevice;
t_func9 PowerGood;
t_func9 Connected;
t_func0 CloseDevices;
int init();
HINSTANCE hDLL;
int foundDLL = 0;
int main(void)
int CardAddress;
int h = init();
    if (!h)
            cout << "DLL found" << endl;
            foundDLL = 1;
    else
            cout << "DLL not found" << endl;
            cout << "Error code: " << h << endl;
    cout << "Press a key to exit." << endl;
    cin.get();
    if (foundDLL)
            CardAddress = OpenDevice();
            if (CardAddress >= 0)
                    cout << "Card #"<< CardAddress << " opened." << endl;
            else
                    cout << "Card not found" << endl;
    if (foundDLL)
        bool ret;
        cout << "Press Enter to \"PowerGood\"" << endl;
        cin.get();
        ret  = true;
        ret = PowerGood(CardAddress);
        cout << "--------------  PowerGood " << ret << endl << "-------------"<< endl;
        cout << "Press Enter to \"Connected\"" << endl;
        cin.get();
        ret = true;
        ret = Connected(CardAddress);
        cout << "--------------  Connected " << ret << endl << "-------------"<< endl;
        cout << "Press Enter to \"CloseDevices\" and to \"FreeLibrary\"" << endl;
        cin.get();
        CloseDevices();
        FreeLibrary(hDLL);
return EXIT_SUCCESS;
int init()
hDLL = LoadLibrary(TEXT(“K8061.DLL”));
if (hDLL != NULL)
OpenDevice = (t_func5) GetProcAddress(hDLL, “OpenDevice”);
if (!OpenDevice)
{ // handle the error
FreeLibrary(hDLL);
return -2;
CloseDevices = (t_func0) GetProcAddress(hDLL, “CloseDevices”);
if (!CloseDevices)
FreeLibrary(hDLL);
return -3;
Connected = (t_func9) GetProcAddress(hDLL, “Connected”);
if (!Connected)
FreeLibrary(hDLL);
return -4;
PowerGood = (t_func9) GetProcAddress(hDLL, “PowerGood”);
if (!PowerGood)
FreeLibrary(hDLL);
return -5;
return 0; // OK
return -1; // error load DLL
[/code]
The error 5 seems to be a timeout error. The .EXE doesn’t wait for the delayed result from the disconnected card long enough.
Here is a link to download modified DLL version 3.0.0.3:
box.net/shared/n8xbsvghda
You’ll get now correct results to the Connected function.
The first call to the card after disconnecting it, gives anyhow also the error 5.
[quote=“VEL255”]The error 5 seems to be a timeout error. The .EXE doesn’t wait for the delayed result from the disconnected card long enough.
The first call to the card after disconnecting it, gives anyhow also the error 5.[/quote]
[color=#0000BF]I found a new problem.
When I call CloseDevice(0) (The device was successfully opened with OpenDevice) a SIGSEV signal is received.
Is this corrected in the new version?[/color]
I really was making a mistake, sorry :wink:
thanks by all the answers, I’ll try to check all this afternoon.
[quote=“pablodurcas”]Hi,
[/quote]
That is like disconnecting the red wire of a bomb, except that in this case it will nearly always blow up. Use the Windows API function RegisterDeviceNotification to find out when a device is being unplugged and disconnect the card gracefully before it happens so the kernel can free up its handles. Or simply do not disconnect the cable of a device that is in use.
