VM110 card
this is a question for velleman support.
Can you explain how can i program PWM ?
I don’t find it on K8055_C.dll and manuals instructions
Thank you
In the manual on p.14 is mentioned: “the analogue outputs and PWM outputs are always activated /deactivated together”.
You get the PWM output proportional to the analog output.
For example: Set the analog output to 127 the PWM is 50%.
