VM 100 powersupply
Can I use one (2x30v ) powersupply for 2 VM 100 units?
For best results, we recommend to use separate power supplies.
Thank you for your prompt reply
Due to spaceproblems i am forced to use only one powersupply and I wandered wat te consequences would be for the output ( use it for a guitar amp)
Wiring is more critical and can easier lead to hum problems.
Thank you
How can i bridge the two VM 100 amps for mono (one speaker) use?
Peter
Sorry, bridging is not supported for this item.
I am reparandome the stage of power VPA2100MN, but need, please the scheme, as tensions hay that it take into account, and components that I can not identify do value, hope as a veleman customer, and expert in the field, that portion I’m inclined by inform as I can locate the schematic components and tensiones.gracias for your attention.
VPA2100MN is NOT a product of Velleman Projects/kits/modules and therefore is not supported by this forum.
Please use the support link of the device itself: velleman.eu/support/contact/?product=361128
Indeed, follow the link provided by laserguy. Fill in the form in your native language, we have spanish speaking staff who may be able to act as translator.
