Who can help ?
After changing the CD4080B the unit worked fine.
In the menu, i turned down the contrast .
I cannot turn it up again ?
I only have a blank LCD.
Is ist possible, to do a reset ?
Who can help ?
I hope you can help me !
If it is not possible, to make a hard Rest - this unit can not be used anymore !
Use Case:
Menü -> Contrast : there you have a number e.g. 37
Pushing the button right beside the LCD, it decreases the contrast.
I thought, it will decrease and than again raise again.
But no, it decreases until zero, then the LCD is blanck, and it is unpossible to use this
unit anymore !
It seems the microprocessor is storing this value. Even removing the battery, the LCD ist still blank !
It seems, there is a Software failure !
Decreasing the Contrast means, you must give this unit back for warranty to the reseller, it is not possible to use it anymore.
A reset isn’t possible.
But you can try this to get the contrast back on LCD.
Please try these steps:
Hope this will help.
If it doesn’t work with these step, you can bring it back to shop where purchased for RMA REQUEST.
Best regards,
Velleman Support.
thank you very much, yes !!!
it works now again !!!
Nice to hear it’s working again.
Have fun with this tester.
Best regards,
