I have assembled all but the KST MW004 the problem I have is the board has a layout of the four pins in a square then eight pins in a row with a space between two then another six. the component in my kit is KSE MW004-578B which has the four pins in a square but nine pins in a line, this is different to the layout on my PCB and one pin to many, your advise would be very helpfull,
Regards Gary.
Could you post a picture of the pcb and the module?
I can confirm that 1 pin is floating when soldering the FM module
Thanks for your reply, there dosen’t seem to be a way of posting images to this forum only a reference to a “public web server” which one should I use ?
Regards Gary.
Yes thats correct, i personally prefer imgur
Here’s a picture of the connection for reference
Thank you for posting the Image, it now is clear that I have the right FM receiver, you have been most helpful,
Many thanks and regards Gary.
