Upgrade PCS100 (time step)
I work with the PSC100 to solve electronic problems in the automotive field.
I’am a teacher in a mechanical school in france.
I try to find a simple way (as cheap as possible) to observe all the needed signals of the automotive diagnosis. My aim is to allow students to have their own “diagnosis tool”.
Pc oscilloscope are really too powerful and so too expensive.
What we really need is a PSC100 like but with a time step of 0,5 ms (as far has i know, the PSC100 is 10 ms).
So I got 3 questions :
1 - Can I use the DLL routine to “check” 2000 times a second the values of the PSC100 inputs ? (I don’t think so but …)
2 - Can I change the “software” in the PIC to increase the time resolution ?
3 - Or, no way, with the actual electronique circuit, 10 ms is the minimum time step value.
That for reading me.
Really sorry for my english of french engineers :S …
Tom
So if I understand you are looking for a small, inexpensive device, connected to a computer, that can sample several signals at 2000 samples/sec - is that correct? What are the other key data? E.g.
  • how many channels need to be monitored?
  • what’s the voltage range? (0 to 5 Volts, or other?)
  • triggered on one of the channels (or separate trigger channel) or free-running?
  • necessary record length (how many samples)?
  • always 2000 samples/sec, or also faster/slower?
  • how many of those devices would you need, and what would be the budget for that? (you say the PC based scopes are expensive, so I assume less than that)
  • real-time (scope-like) display, or simple capture to text file?
I may be able to help you find what you need. If you are interested, contact me at gwen.and.wolfgang[at]sbcglobal.net (replace the [at] with the @ sign!)
Wolfgang
Hello vrince.
Sorry but the sampling speed of the PCS10 can’t be increased from the 10 ms rate. The speed is based on the USB standard. The polling frequency in the low speed USB communication, that the PIC in the PCS10 uses, is fixed and can’t be increased.
Sorry that no solution to your problem at the moment…
Ok that’s unfortunatly what I though.
Do you think it’s complicated to realise what I need ?
I assume we don’t have access to the PIC’s software used for the PSC100 circuit … as an example.
Is Velleman develop special circuit ? We never know …
Thanks for those very quick replies.
You wrote “PCS100”… I think you mean PCS10 anyhow…
The sample rate you requested may be possible by using a full speed USB PIC (e.g. PIC18F2550).
It is complicated to realise: You have to develop new PIC firmware and new PC software for the communication.
If you anyhow want to try, then change the IC1 to PIC18F2550, change X1 to 4MHz and remove R1. Then you need PIC programmer (e.g. ICD 2), MPLAB development software and the free C-compiler from Microchip.
Then download Microchip Custom Driver package to start…
The speed seems to be anyhow a problem. Even this professional data logger reaches only 50 S/s when software paced:
measurementcomputing.com/USB … specs.html
[quote]Throughput
Software paced
50 S/s
Continuous scan
1.2kS/s
Burst scan to 4K sample FIFO
8kS/s[/quote]
Seems you are just between chairs - 1 ks/s is faster than most inexpensive data loggers can achieve, but pretty slow for a scope (which is much more expensive). If you are interested - and provided Velleman can’t provide what you need, since I don’t want to steal their business - I could put a simple but usable solution together within a few days with the following performance:
  • 1 kSamples/sec on 2 channels, resolution 10 bits (could also do 4 channels but with slower acquisition rate)
  • real-time capture,
  • adjustable voltage range if necessary
  • connection to PC through standard RS-232 serial port
  • PC waveform viewer software with trigger on channel 1 or 2, pre-trigger display, or continuous capture into a file.
All that should cost less than US$50 per unit, including parts, a printed circuit board, and an enclosure. This assumes a sufficient number (at least 10) of the unit is built. I would do this for the fun of it so I’d do the development and manufacturing at material cost, and not charge for my time.
By the way, feel free to write me in French if that is easier for you.
Wolfgang
gwen.and.wolfgang(at)sbcglobal.net
thank you all.
I bougth a USB-1208FS.
8 Analog inputs
250 S/s software paced
50 kS/s continuois scan
extreanl trigger …
  • 16 digital inputs …
a little bit expensive … but seems powerful.
some small electronic devices and perhaps and nice diagnosis tool :slight_smile:
Thank tou all again.
