i bought some upgrade kits. Header 8203, z-axis 8204, and plate 8206.
Now i have a question.
Must i upgrade firmware for all parts step by step or just the highest firmware from K8206?
Question for the EEPROM reset. Must i short also the pins on the JPROG connector during the reset ?
Because i tried both ways and both ways i get the message succesfully in repetier host…
You need to upgrade firmware for the K8203/4 combination, see Velleman site.
The K8206 does not need any other firmware, but you have to change the maximum printable area in the repetier software only, change y dimension from 200mm to 400mm
