Trying to get going again
Thanks WW, but its more fundamental:
A close inspection has revealed a burnt out connection. The componenet that sits just above the blue input terminal block - I think it’s a thyristor, has blown - it’s the central connection that has gone. Has anyone else had this problem and might there be an underlying problem? I am hoping that if I search on the printed number I can find a replacement.
All the best!
Andrew.
Are you talking about the one that has 7805 on it?
If so it’s a 5 volt regulator.
If this is the problem none of the axis would work.
That’s the thing- I tested it for 5v a while back. I just wired one with a higher output into my old Landrover to replace the electro mechanical voltage stabiliser. I suppose I need to find something that converts 15v to 5v.
Andrew.
