What means non retriggerable? Does it mean that I cannot start a new sequence while a sequence is already running. With other words: Is it necessary to stop an already running sequence before being able to start a new one. If so, could I start a new sequence by activating the stop and start inputs at the same time?
The idea is to make the timer retriggerable. I want to connect the start and stop inputs with a diode in order to pull down also the the stop input when activating the start input. Would that work? Which diode polarity would be required? I cannot see this from the wiring diagram.
