To short field range for the K5058
I have a K8056 and a K5058 thats works fine. But a want to put it in my new house, in the garage. But this gives me a major problem.
The field range (5Om ?), is max. 10m and using de RF transmitter from the sleeping room, it d’not go trough the concrete floor. How can I increase the field range. Maybe putting a extern antenne on the antenne unit of the K8056
K8056 is equipped with external antenna input.
There is a bridge between the RX433 and a think an antenne that is printed on the K8056 board. Where should I solder ore connect a external antenna ?
Remove strap for internal antenna and solder antenna to point marked ANT…
tought so. Thanks very much.
