Time/div behaviour
When you have logged a trace in the oscilloscope part of the PCSU1000, you have the possibility to go 2 steps higher in the Time/div scale. Going further makes your signal disappear.
An example to make the above more clear:
I have a log taken with a time/div of 0.2ms. While the image is stable, I can reduce the time/div to 0,1ms and 50µs.
But when I try to go one step further (so, a time/div of 20µs for example), then the signal is gone.
However, sometimes it’s needed to see the signal even more in detail, so having an even higher granularity would be welcome.
Two questions:
[ul][li]Why this limitation? Is it the sample frequency?[/li]
[li]Any chance this can be improved?[/li][/ul]
Best rgds,
–Geert
Actually all the data is displayed when you “zoom” the waveform display by two time/div steps. (One pixel on the screen correspond one data sample.)
Anyhow, as you wrote, in some cases it may be good to look the data even more detailed.
Thank you for this suggestion - I think this modification can be included in the next release of the PC-Lab2000SE…
