Thermometr and gas sensor for VM110
Hi…Please help! I need to get current temperature in the room and i’m using VM110 for this. Also i tried to get the data from DS18B20 digital thermometr but no results…I read that VM110 does not supported DS18b20 and now i’m searching for digital thermometer which able to connect at VM110. Could anyone tell me which thermometers(brand and model) are 100% worked correctly with VM110?
Thanks a lot!
And one more question…I’m going to connect gas sensor to VM110/ Here is the link: figaro.co.jp/en/pdf/2611ProductInfo0205.pdf
Will it works if i connect it to the analog input?
Check VM132 temp sensor.
http://www.velleman.be/be/en/product/view/?id=362018
Sorry, no experience with gas sensors…
[quote=“VEL417”]Check VM132 temp sensor.
Sorry, no experience with gas sensors…[/quote]
Thanks, but i’m lookinig for more simple, more compact sensors…like Dalas 1-wire sensors…
