hello foks of velleman i get my self a tri-t model cg046-3007-01 4/8 bit 2x16 display and evry thinmg is hooked up richt on j10 port from 1 to 10 are in use it seems that it worked now i dont see time or title song i see strange markings and only 1 line instead of 2 lines and when i turn up the potentiometer to max one line get black squars its the second display 1st one got blow by wrong whireing my fold mp3 player stil ok second display is hooked up richt j10 pins from 7 8 9 10 are the db lines 1 trouh 4 on j10 1 trouh 6 are richt as wel i have checkt bhot diagrams from pcb and display chekt evry thing 3 time per whire i only dont use the back licht no need for it because lcd whil be mounted in my cockpit of my scooter zo i can see what song is on while cruising coming summer
could you please use punctuation and capitals otherwise it is very difficult to read i’m sure you’ll understand thank you
I wil try to ok i start over i got my self a alternate display from the tri-t company its a 2 by 16 lcd on the page of tihs site you wil see as wel a alternative display mounted on to the mp3 kit i have the same problems as any one else whit it i made sure evry thing is corectly wired my lcd stay off when i reconect the no lcd shunt it pops on but instead song title i got markings and one line of matrix comes on i made sure that evry thing is conected corectly any sugestions how to solve this already try evry thing even from this forum
i make use of a tri-t MODEL CG046 3007 LCD
THANKS FOR ANY HELP SO FAR AND YOUR QUICK RESPONSE
Still no punctuation, capitals or other things that makes your text readable! Help us by showing some effort to make our life easier when reading, and the people here will be more likely to help you. This is a “general law” for all forums.
paulus27: Have you tried with the original LCD module for the K8095? Isn’t it working too?
