My English is not so good.
The K8101-Kid doesn´t connect with my Win7-64 PC, but it connect with my Vista32 Laptop!
When I connect it with my PC, there are not question for Driver and it isn´t find in the Drive-Manager.
There are no Reaction on my PC!!
I have tested cheap and expensive cable and all USB-Ports + HUB :-((
On my HUB the Indicator LED for the Port, where the Kit is connected, are not lightning!
Thank You for your help.
I have not found the problem, but I have connect the kit on an old USB-HUB
and these HUB an my PC.
What do I say??
The Massege-Board K8101 is connected to my PC!!
Gruß
Bleiplombe[/quote]
let me summarize to verify if I understood that correct. The display functions with the new Win7 PC when you use an old hub, but not directly connected or with a new hub. It does also function with your old Vista laptop, directly connected or with hub.
If that is correct I would say that your new PC has problematic USB ports.
[quote=“MostlyHarmless”][quote=“bleiplombe”]Hello Jan
Thank You for your help. I did try to read the [color=#4B5C77]page[/color] that you gave me, but I still have some issues.
What do I say??
Gruß
Bleiplombe[/quote]
let me summarize your [color=#4B5C77]situation[/color] to make sure I understood it correctly. The display functions with the new Win7 PC when you use an old hub, but not directly connected or with a new hub. It does also function with your old Vista laptop, directly connected or with hub.
If that is correct I would say that your new PC has problematic USB ports. You may need to [color=#4B5C77]contact[/color] the manufacturer.
Mit freundlichem Gruß
Jan[/quote]
So ultimately this entire issue comes down to problematic USB ports from the best of your knowledge?
