Support material
In slicer I go into the configuration area for simple mode and check generate support material and save. Slice the part and run it and there is no support material. What am I not doing correctly?
Did you select the right slic3r profile in repetier?
If you recently changed it you must reselect it to make repetier respect the changes.
cheers,
Christian
Thanks that solved it.
Nice to hear!
Happy printing!
