Settings call from invoking shortcut?
I see several posts on PCSU1000 settings saving and recall;
is there a way to invoke a previously saved/named settings recalled
on the (windows shortcut link) command line? say as command line argument? this saves a bunch of time becuase I could make a bunch of shortcutz for various applications and so on.
I see the new software on the site is a vast improvement over the previous load just a few months ago.
good work
obviously the best value USB Digital Oscope out there
very good to have when on away missions into central and south america because its not as bulk as my $4K color-100meg Tek with nearly the same features and function
Glad to see that you like the new software and the easy use of the PCSU1000 oscilloscope.
At the moment the only way to save and recall the settings is to use the File menu options “Save Settings” and “Recall Settings”.
Indeed, your idea to load the settings file at startup using the command line of windows shortcut link is very good!
This is a small modification and it will be added to the next release of the software.
