[quote=“VEL255”]Nice that you enjoy the PCSU1000 scope.
Indeed there is no settings.ini file anymore. Now the settings are saved to settings1000.ini file. If you run PCS500 then the settings are saved to the settings500.ini. The files are in the PC-Lab2000SE folder.
Regardless you seem to be quite satisfied with the PCSU1000, anyhow I’d like to solve the “issue”.
Could you please still do some more tests that may help me to assume the reason to the problem.
- Set the markers on in scope, spectrum analyzer and in the transient recorder.
- Check that the “Save/Recall Last Settings” is checked in the Options menu.
- Do some changes to the Volts/div, Time/div, Y-position etc. settings to see that the settings will be restored.
- Close and restart the program.
- Check that the changed settings are restored correctly.
- Check if the markers are displayed on any of the screens: Scope, spectrum analyzer or transient recorder.
- If not visible then click the mouse near the upper edge on the oscilloscope screen and drag the mouse. Is there anything (marker line) displayed on the screen.[/quote]
Dear VEL255
I think we did misunderstand each other and somehow the application behaviour seems not to be consistent as to the settings save and recall.
Please, let me describe the “issue” once again.
I have done the testing you suggested and what I ahve noticed is the following:
Please, note that for these test Save/Recall Last Settings option under the Option menu item is not checked. I have also an ini file in the application folder that is named settings1000.ini.
The tests:
1 - No DSO Markers and no Bright Grid
You can save and recall as many times you want the recall is correct, i.e. no DSO Markers and no Bright Grid are checked nor visible.
2 - Bright Grid and no DSO Markers
You can save and recall just once. the second time you make a settings recall the Bright Grid wont display even though checked in the View menu item. of course if you save again with the check and the display correctly set, then it will work. Yo can also save the settings with the Bright Grid checked and not visible, these settings will be recalled exactly as saved, i.e. Bright Grid checked and not visible.
3 - DSO Markers and no Bright Grid
This work perfectly even though you save and recall as many times as you want.
4 - Bright and DSO Markers
The situation is as described under test 2, i.e. the Bright Grid is not restored and the DSO Markers are restored.
I am sorry it it’s too complicated as I did explain it and I am ready to do any further testing for you, just let me know.
Setting or not these DSO Markers under the other functions doesn’t seem to change anything to the behaviour described in the 4 tests.
I assume this covers the testing you wanted from me and if it’s not the case, please, let me know.
Many thanks for your patience and
Best wishes and have fun.
