I have added a PSU to my Velleman K8200, making the heated bed run on a 24V PSU.
But I was wondering if it was ok to use a single PSU, with a little better specs.
I found a 15V 24A 360W PSU, would that work on the Velleman K8200?
/Peter
/Peter
[quote=“EmracingDK”]I have added a PSU to my Velleman K8200, making the heated bed run on a 24V PSU.
/Peter[/quote]
It will work, but you won’t have better hearting, cause the Voltage stays at 15V.
Hi
I replaced the original 15v supply with a 24v.
Everything is running on the 24v supply.
Neil.
[quote=“NW27”]Hi
Neil.[/quote]
So you power the whole controller board from 24V?
Watch closely for Overheating Voltage regulators then!
The 15v Velleman uses are already out of spec…
