Repetier rev 1.06
has anyone try this version and especially the cura engine i tried the engine but it was not behaving right so i stopped using i think there must be tweaks needed for the .ini file I would appreciate some help.
I use repetier host 1.0.6 with the cura engine daily.
No need to tweak.
Please describe your problem.
Not behaving … isn’t very handy.
Did you set up cura engine independently?
cheers,
Christian
Repetier Host by Velleman includes the standart slic3r settings (not the cura settings).
That is the hole difference. Nothing more.
