Programming the pic 16f628-04/p
I use the velleman pic programmer which I bought already built.
I have a project which requires a pic 16f828(a). I only have the -04/p.
Apparetly it can be programmed just like the (a), however I cannot select the config word 3f42 which enables me to uncheck/check the mclr and other switches. If I select the pic16f628 in the menu it looks like it’s getting programmed correctly however then I click on the view config and I don’t see the port/switch names (mclr,etc…), that I can see if I select pic16f628a, but it doesn’t like it’s getting programmed correctly, it’s going too fast.
Any ideas, I’m a newbie at this.
Thanks,
Pierre
