Problems with vu meter (K4306)
Ld1,5,11,13,15,19,19 is always on
Are you sure you mounted those with correct polarity?
Could you post some Clear pictures of the top and bottom of the board?
[quote=“Wrong Way”]Are you sure you mounted those with correct polarity?
Could you post some Clear pictures of the top and bottom of the board?[/quote]
is on the correct polarity only is on this leds on when I conect the vu meter
ic5 is so hot
This would indicate a short or something in backwards.
