I use the K8067 sensor board. I made it because it’s for school (My end year). Now we have some problems. When we put 12 V+ like in the datasheet on the R11 we don’t see a change at the output. It looks like the LM335 don’t respond. We don’t know the problem. Is it also true , you have to not connect PIN3 of the LM385 ?
Regards Nicolas and sry for the language
The K8067 is a current loop sensor, you cannot measure a voltage change unless you correctly terminate the output with either 500 or 250 ohm, as indicated in the manual.
LM385 is a two pin device.
So i’ve i’m right , we can’t see a voltage change at the output ? How can we know i’ve our print is working ? we get 10 V at the output i’ve we put 12.7 V at the input.
Regards
Please read my previous post AND please read the manual of this kit !
You must terminate the output of the kit with either 250 ohm or 500 ohm. The resistors are supplied with the kit. Measure over the resistors.
[quote=“VEL417”]The K8067 is a current loop sensor, you cannot measure a voltage change unless you correctly terminate the output with either 500 or 250 ohm, as indicated in the manual.
LM385 is a two pin device.[/quote]
I measure a light voltage change at the output when i put 12.7 V at the input. The change goes from 0mV to approximately 0.500mV , is this normal ? And a final question . Our LM335 is connected with a potentiometer but does this potentio have to give 0 our 5V to the LM335 ?
Grtz
P.S IC is not TLV274 but TL024CN (also good ?)
This is not correct.
Did you terminate the output with either 250 ohm or 500 ohm ?
Are you sure you did not mix up the sensor and the reference diode ?
If the IC is the original supplied with the kit, then it should be OK.
We suggest you return your kit for inspection.
Please return it to:
Velleman Kit Repair Dept.
Legen Heirweg 33
9890 Gavere
Belgium
Turn potmeter on K8055 until you get max. reading (255) using test software. Next, remove the jumper and connect K8063 WITH correct termination resistor or sensor. The K8063 is a CURRENT loop sensor, so you must mount the 250 or 500 ohm resistor, depending on the desired output voltage, as indicated in the manual.
